Esta vez no es broma (tenía que hacerla), esto sí es de verdad:
Del twitter de Tiy's.
Enviado desde mi Nexus 4
Menos mal lo de las naves, que ya no me cabían los cofres.
El futuro de starbound.
So here is a non exhaustive list of additions coming to the game. We have a lot more than this in store (not yet discussed), but Xealaz over at reddit compiled such a nice list of the stuff we HAVE discussed that I wanted to share it with you. As always, things are not set in stone.
On with the list!
NPC Spawners & Building Logic: NPCs will scan the structures you build around them and the contents of chests; they will have improved inventories/behaviors depending on how valuable their surroundings are.
Macro Terrain Changes: Affect an entire planet’s terrain and weather
More Planet Scanner Data: See details in the planet scanner like planet occupants/dungeons
Underground: More secrets will spawn below the surface
Space Combat: Way in the future, expect space combat and the ability to board other ships.
Spaceship Dungeons: Very large, size of a planet.
Biome Hazards: Sandstorms, icestorms, meteor showers, toxic planets, airless planets.
Ore & Difficulty: Higher difficulty planets will have improved ore distribution
Story Missions: Eventually each tier will end with a story mission that ends with the bosses you see now.
Ship Navigator Changes: Still not set in stone; but the new idea is to give a local map with fog of war. Instead of sector buttons you have to fly out of a sector and into the next one by uncovering more of the star map. The final sector would be infinite.
Smoother Difficulty Curve: Better indication of the difficulty of an area. Difficulty will change within tiers as well as between tiers. There will be fractional difficulty (for example, Difficulty 1.12 in tier 1 would be easier than Difficulty 1.52, while still in T1)
Monster Generation: Right now, monster parts just have stat boosts, but eventually rolled monster parts will affect their behavior and abilities. For example, monsters with spider legs can climb walls; fiery monsters inflict burning. You might get a burning spider dropping on you from the ceiling. Projectiles may be tied to specifically generated heads. Biome may influence monster part generation.
Mini-Map: Rotating circular map showing highlights only such as the location of friendly players, spawn points–but no major details. For the details you’d use a mapping item to create a map as you travel.
Teleporters: Stargates between planets and eventually between servers.
Dramatic Planet Modification: Not going to be implemented any time soon. Ability for players to modify huge chunks of planets through things like orbital bombardment; removing the entire first layer of a planet and leave behind a lifeless surface.
Tech Priority: Eventually all techs can be active at once, but a categorization system is in the works to assign priority to conflicting techs, preventing issues. A hotkey to switch the active tech will be added as a temporary workaround until the priority system is completed.
Server Commands: More server commands and control for chat and port listening.
Villager AI: Villagers will aggro when you steal from them and follow you more aggressively.
World Storage: Improve world storage and organize *.pak files to improve modding. Add launcher integration.
Spawn Points: Change spawn points on individual planets.
Controls: Reconfigure controls; keybinding.
Ship Size: Upgrade ship/increase size.
Racial Armor: Racial abilities will not be inherent but will be tied to racial armor. For example, Avian armor can glide downward.
Capture Pods & Mercenaries: May be able to capture NPCs with pods. Summon NPC Mercenaries by using the pod as a beacon.
Reduced Wipes: Working on a system to patch without requiring as many character wipes in the future. This will require one more wipe and that’s it.
Other Changes: Colorblind Mode & Engine Optimization. FTL animation being revamped to reduce memory strain.
http://playstarbound.com/the-future-of-starbound/
Tiy @Tiyuri
Congrats to Apjm for getting his skyrails mod into the next update http://i.minus.com/ic8MXRdKtEezx.gif … we're adding animations and polishing her up now!
Changelog for v. Angry Koala 23/12/2013
A ton of new content in this update. We've added a bunch of new features to world generation,
which might require you to start on a new universe. To make sure you get access to all the new
crafting items you either need to unlock sectors again or create a new character.
Also..
Por fin se pueden replantar arboles
Enviado desde mi Nexus 4 mediante Tapatalk
